kamal50
Posted on - 08/10/2011
My computer's cd rom had been damaged for this reason I've bought a new cd rom but when I'm trying to set cd rom with my PC it shows an error when I'm inserting a CD into cd rom it doesn't play it.
I need a quick solution I'm looking to hear something about my problem.
Jack034
My CD rom doesn’t work properly
Your PC's CD ROM is new but it is not working. The cause of your CD ROM's problem is for having problem in your cable. Your cable might not work perfectly. Change the cable then your problem might be solved.
If there is still problem then check your motherboards IDE port/SATA port.
You should change your Windows. Resetup your windows.
This problem often occurs due to bad connection. If you are not an expert then do not try to open your CPU yourself. Consult to your nearest PC servicing Centre or replace the CD ROM. Thus it is a new one you have warranty. So, quick solution of your problem is resetup your windows.
j4ck5
I need calendar script maker in JavaScript that can be used in web pages or on the computer to create a Calendar and post them on the web site.
It should be editable (including background image, background color etc.) print them and should also save them.
Which should also allow us to customize the font, size, color and setting etc.
Please do the needful.
