Hi, the problem is associated with my CDJ 200 where it is ejecting any CDs without reading them. It shows error code 8403 on the screen. I cleaned the disk using compressed air, but the problem was as usual. Please let me know how to solve this problem. Thank you.
My CDJ 200 ejects CDs and encounters Error Code 8403
Hi Eckel Andrea,
I’m sorry to hear you are having issues with your disc player where it is ejecting discs without reading them. Error 8403 means that the discs inserted is unreadable. Now in your case, the disc is not being read in the first place.
The mechanism that takes in the disc is stuck on something. You may need to have a professional disassemble it and find out what is stuck where.
There’s also a chance that the laser head reader and or the ic protector is defective that’s why it continually pops the disc out without reading them. Replacing those is a cost effective solution.Â
This is a known issue but tinkering inside the equipment itself will void your warranty.
I Hope that helps!
