Hi Experts,
I am a regular user of internet through my iPhone 4. It works quite smoothly unless I come across a captcha. On most of websites I cannot see the characters of Captcha. Please help me solving this problem. I have heard about Captcha Mobile Application (of drawing images). Does this application solve such problems?? If yes can anybody help me find this.
My cell doesn’t show captcha . Help to get mobile captcha application
Hello Asten Rathbun,
There is a problem with your installed browser. Sometimes, there are problems if you install any unwanted plugin. First, uninstall your plugins, and if that does not work, uninstall your browser and reinstall it. Then it will work.
Best of luck.
Hello.
This can be caused by numerous things.
Make sure that Java is enabled on your phone
Disable any firewalls and popup blockers etc and then see if the captcha's now show.
Try installing an alternative browser such as Firefox or Chrome.
Delete the history and cookies in your browser
If it's a difficult captcha just enter the first characters of the captcha code or choose the audio option and listen to the captcha code.
