My Comodo Internet Security has encountered an application error
Hi guys,
My Comodo Internet Security has encountered an application error. It is throwing an error message saying “The exception unknown software exception (0X0000409) occurred in the application at location 0400713b0.
Click on OK to terminate the program” frequently.
I tried to solve the problem from different settings but failed.
Please help me.
Best Answer by Vinson forman
Answered By 0 points N/A #191532
Hello Green,
In order to fix cfpupdat.exe Windows error, you will need to follow the steps below:
  • First you will need to download and then install cfpupdat.exe Windows Errors Fix Tool for FREE.
  • After that run a Performance Scan Your Computer.
  • And then click the 'Repair Error' Button to Repair.
Nicke
Answered By 0 points N/A #191534
Hi Dear,
Comodo Internet Security's this error shows that you have to need a proper update required. Because internet security should be automatically updated on daily base.
On windows 7 64 bit version, it has daily update required. Please make sure that update settings are working properly?
There is no application's codec mistake.
If problem remains, please reinstall your software for security enhancements.
Thanks
Answered By 0 points N/A #191536
A simple update can help you fix the problem. After running the Comodo Internet Security, check if there are updates available for download. Maybe you have a version that is already outdated and it is always recommended to update it to the most recent version to be able to use it. If this doesn't fix the issue, try to remove your Comodo IS and then reinstall it again. You can download it from the link given below:
https://www.comodo.com/home/internet-security/free-internet-security.php
