davewilson
440 points
Posted on - 05/26/2011
While I was surfing the net, I accidentally opened a site that contains malware. My anti virus is outdated,since it came as a pre installed program when I bought my laptop.
I did not buy a legal and premium anti virus since I don't usually use my computer. And I only use this to communicate with my family and friends outside the country.Â
While searching on Google, I opened a site that has malicious content. Without knowing that I been hit by a malware virus. My system suddenly slows down, and display repeated error message.
I cannot even shut it down or restart it. And even if I'm not surfing the web, there is a continues pop up message that appears on my screen. I was about to reformat my laptop because I don't know anyone who can lend me an original anti virus disk. When I inserted the disk in my DVD, my computer did not read it.Â
There is no drive for DVD on My Computer window. Normally, when I insert any disk, an Auto Play box will pop out. But this time, I did not see anything on my screen and I don't know how to open it. How can I possibly reformat my computer even without the recovery disk? I am thinking that this error may be because of the malware virus I got. Please help…
Specs:
Compaq Presario C300
Windows XP Home Edition 32-Bit OS
1 GB RAM
80 GB HDD
Celeron
My computer cannot access my DVD Drive
If you cannot access the DVD drive of your computer then you can try the following things. You can try to install a new driver for your driver. You can download the latest driver for the DVD drive of your computer from the website of the manufacturer of your computer.
Before installing the new version of the driver you must first uninstall the old driver from the computer. For uninstalling the old driver, you can click on the start button and then you can select the control panel. From the control panel you can select the device manager. In the device manager you can see a list of devices which are installed on your computer.
From the list you can select the DVD drive. You can right click on the DVD drive and then you can select the uninstall device driver. This will uninstall the device driver for the DVD drive from your computer. After uninstalling the device driver from the computer you can restart your computer.
You can then install the new version of the DVD driver by double clicking on the installation program that you downloaded from the internet. After installing the driver you can check whether the drive is working properly. If it is working then you can insert the recovery disk and then reformat the computer.
Another option for you is that you can try to format the computer using the pen-drive. You can copy the files to your pen-drive and then you can try to boot from the pen-drive. You can insert the pen-drive into the USB port and then you can restart your computer. Then you can press escape button or the F2 button on your computer to open the bios settings.
From the bios settings you can select the advanced boot options. In the advanced boot options you can select the boot device as pen-drive. Then you can press enter. So now your computer will boot from the pen-drive. You can now format your computer to remove the virus from the computer.
You can also try to boot the windows in safe mode. For booting it in safe mode you can restart your computer and then press the escape or F2 button to access the bios settings of your computer. In the bios settings you can access the advanced boot options and then select the safe mode. You can then check whether your DVD drive can be accessed.
You may also use the fixit software that is available on the Microsoft website. You can run the software and diagnose the problems of your computer if any problems where found then it will automatically try to fix it.
Another option is to edit the registry. Before editing the registry you should make a back-up of the registry. For that you can select the start button and then in the search box you can enter the word regedit and you can press enter.
Then you can select the key or the sub key that you want to edit and then in the file menu you can select the export option. You can then save the file in any location you want.
After that you can again open the regedit and then you can open the folder HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerCD BurningDrives. You can then click the volume folder. You can then double click the drive type. You can then enter 1 if it is read only drive or 2 if it is read/write drive.
Janine08
5 points
Hi Davewilson.. uninstall it from the device manager and reboot and windows will reinstall
lenovo have a good download section with all the drivers,including the restore disks. I downloaded them last week and burned to disk for future use
Hi derrick, I used a USB flash to reformat my pc. Thank you for giving me suggestions to try. Till next time.
If a computer is infected with a virus, system performance is affected. You usually get longer boot time, longer application launch, high CPU usage though no program is running, and so on. If you think your computer is infected, update your antivirus then perform a full system scan. You can also use a virus removal tool like Sophos.
Download Sophos Virus Removal Tool and install. Once installed, start Sophos then wait for the virus signature database to get updated. When updating is complete, click to start scanning your computer. Sophos scans everything on your computer including devices connected via USB port. When a virus is found at the end of the scan, remove it then repeat the scan over and over until it no longer detects a virus.
Don’t disable your antivirus when using the tool. Sophos works alongside any antivirus program you may have. Note: this is not an antivirus so don’t use it as replacement to your antivirus. It is just a tool to remove hard-to-detect viruses. It doesn’t have real-time protection like what antivirus programs provide.
