bonih
Posted on - 12/23/2011
HI! my computer has problem in installing drivers. when i insert a flash disk or a modem installs automatically then in the process displays insert a window XP professional service pack 2 CD and i do not have the CD. How i can i solve this, please help.
My computer cannot install new hardware like a modem
If you want to solved this problem,you will be need to format Windows XP using a Windows XP dise first.So collect a windows XP dise,and follow down.
1.First you must put your Windows XP CD in the Drive.
2.Restart your computer.
3.When it says press any kye to boot form cd,press any key on the key bord.
4.If it dose not ask you to press any key to boot form cd,then restart your computer again.
5.Go into the BIOS setting of your pc.you have to make your cd form the first boot option.
6.When the CD starts up,A blue screen will appear and you are on the way.
After the finishing..you will be able to install your drive again.
Thanks!
You may be having modem driver on your flash disk that are saved as auto play files and that is why they are executing automatically when you insert the flash disk to your computer. You will therefore need to do the following to correct that problem so that the drivers do not start installing automatically.
You will need to open the flash disk and look for the folder that has the modem drivers, and then you will need to delete it automatically.
In case the file refuses to be deleted, then you will need to format the flash disk to as to remove that modem driver, but you will need to backup the important files that you do not want to loose from the flash disk.
-Clair Charles
I think your pc have some virus. So you face this problem. Some days ago I also face same problem.
So I just say what I done.
First time I setup windows XP, but problem couldn't solve. I did it 3 time but didn't get anything. Then my brother suggest me to format the hard disk. I did it and solved the problem.
your problem like my problem. But I think your problem solved by setup windows XP. If don't solve, nothing to do without formatting hard disk.
wish you to solve the problem.
"SABBIR AHMED"
