My computer does not recognize any USB device
I installed windows 10 technical preview and when my computer was ready to use, none of the devices connected via USB worked. I restarted the computer several times, unplugged and returned the devices but none is working. When the computer is beginning the boot process, all the devices work since I can see light on the mouse and keyboard. Immediately it passes the Windows logo, everything stops working. Help me solve this.
Answered By 0 points N/A #186317
HELLO
First check that only mouse and keyboard are not working or all other USB devices not working. Please unplug all devices and after that restart your system. If not work then reinstall windows ten
preview. It can be cause of corrupt windows. If problem exists then it can be issue with hardware. Please visit
your service center for solving these issues.
Answered By 0 points N/A #186319
After installing windows 10 preview, it erased some of the drivers in your computer including usb drivers. To fix this you need to update your divers. Click start-right click on computer-manage. On the new window that appears click, device manager. It shows all drivers available on your computer and the ones marked in yellow needs to be updated. Right click on any of them-update driver-click scan automatically. You need to be connected to the internet so that your PC will browse over the internet to find the ideal drivers for your machine.
Answered By 590495 points N/A #327541
If none of your USB devices like mouse and keyboard are working after installing Windows 10, first thing is you need to check if those devices are working on another computer. Try plugging your USB devices on a different computer then see if the problem follows. If none of the devices worked on the other computer, it is most likely that your devices are broken or got damaged.
In this case, just buy replacements for those affected USB devices. On the other hand, if the USB devices are working on the other computer, the problem is probably with the USB driver on your computer. To fix the problem, just install the latest drivers for your computer. Download from the following manufacturers if you have one of these:
