shaun mike
Posted on - 08/24/2011
I have problem with my computer as it freezes in the middle of my work and i don't make heavy work but i don't know why this happen and i tested the Ram and i don't have any errors and i run manufacturer test and there is no errors and now i want to know if my motherboard has problem or not so please help me in that quickly.
Computer freezes in the middle of working
Computer freezes when doing something means, the CPU is processing a files. To check if computer really is frozen, press the numlock in your keyboard if it responded by turning off/on correspondingly. If it does respond, it means that the Windows is running.
You may need to press CTRL + ALT + DEL to end the task. A simple reboot/shutdown of your computer will let you gain the access back. Here's why computer freezes. Corrupted windows registry. Drivers are outdated and maybe corrupted. virus infection, eats up processor.
File and hard drive system errors. Computer is in back location > Solution is to clean up registry > Update drivers > Run anti-virus scan > Use a diskeeper to analyze computer hard drive > Tried put your computer in a nice place, need to be at dry, cool and cold location so the fan will spin constantly.
Hassan29
It’s not a severe problem at all.
Just follow the instructions below and you’ll get the solution.
Hardware: It may be due to defective or mismatched component in your computer.
Aluminum Migration & ESD: ""Premature ageing Electro static discharge"" can make a computer intermittent or freeze it.
Operating system: Some version of Windows contains bugs which can cause problems.
Drivers: Buggy or incompatible drivers (software) can make these problems.
Software: Some programs have bugs in them this can cause problems.
Memory Fragmentation: If you often see this message ""System is dangerously low is resources"", you are probably suffering from Memory Fragmentation.
You need to use antivirus program to remove virus, spyware, spam etc and in the market several antivirus software are available.
dlanear
5 points
There are lots of problems that shows different Screen of Death. The most common is the Blue Screen of Death (BSoD), most of the trouble with this is the Random Access Memory (RAM) of your computer. It can be too hot and needs to pull in a while and rest for few minutes.
Might be burned cause of over use. Either try to replace it in the meantime or try to check if it will work for other computer. I suggest to have a memory cleaner and test if it will restore to normal. Also check for corrupted installed programs that can contribute to this problem.
Hope it helps.
-Dlanear-
