My computer getting stock or freeze while sending emails
Asked By 490 points N/A Posted on -
When I send emails, my computer gets stuck or freezes, and sometimes, it turns off. I'm wondering what the problem might be. Is there anyone who knows any solution to this?
Best Answer by marvins_18
Answered By 0 points N/A #87899
This problem is probably due to heat. So check temperature with speed fan. You may download almico and install it.
Once you're done with downloading, right click on SF icon and choose "Run as Administrator".
See more and read procedure.
Answered By 0 points N/A #87900
Oftentimes, it is affected by a virus infection. You have to fix it with Microsoft Security Essentials and you should do a ‘Full Scan' of your computer. This will help you to find and remove any viruses that might have infected your computer.
Answered By 490 points N/A #87901
It is probably caused by heat, because of too much use. I will try if that speed fan tester works. I have an Antivirus too.
Answered By 0 points N/A #87902
By the way, have you updated your Windows through the best recent Windows Update? It is recommended to all users that they should run Windows updates especially every morning.
Answered By 0 points N/A #87904
Maybe, the problem is with the Power supply. As far as I know, a definite computer’s failure can be due to an undersized power supply or incorrect voltage. So, you must determine the availability of the power supply that will be needed for the total load.
Answered By 490 points N/A #87905
Guys, there were so many things that I learned today. Thank you very much for the information and advices from the both of you. I've totally found the answers here.
Thank you!
