My Computer Gives Out A 0xc004f014 Error While Upgrading The OS
Tell about 0xc004f014 error? what is the cause of the error code, and explain the methods to overcome this error message?
Error code 0xc004f014 is a Windows 10 activation error. When the user uses a new license key for the up-gradation of the Windows in OEM systems. The error code shows, ‘We couldn’t activate Windows. Try activating Windows again or contact Microsoft support and reference the error code. You can go to Settings for more information.’
The solution to fix the error code is as follows:
Solution 1:
Use Windows Media Creation Tool
Step 1: Navigate to the Microsoft website and download the Windows Media Creation Tool.
Step 2: Right-click on the .exe file and run as an administrator.
Step 3: Accept the agreement, then click on Next.
Step 4: Click on the Create installation media and press Next.
Step 5: Set the language, architecture, and edition of the recommended option for this PC option.
Step 6: Select Windows 10 Edition and Architecture, then click on Next.
Step 7: Plug-in the USB flash drive and click on Next.
Step 8: Wait for the installation to finish and reboot the system.
Solution 2:
Use Windows Troubleshooter.
Notifications
