My computer goes slow at the time of work
How can I get speedy my computer when I work with it?
Can any one give me advice to remove the problems?
Causes and Solutions:
1. Low HDD space.
(Run Scan disk and Run Defrag)
2. Group over programs and bad files.
(Remove unwanted startup programs through “msconfig”, and check anti-virus if you have that may be running in the background)
3. Corrupted data.
(Check spyware and malware on background, stop them too)
4. Old Windows updates / old driver database.
(Always keep auto update for windows, and keep your system’s drivers up to date)
5. The system is heating up.
(If a processor gets over heated it reduces the performance)
6. Dissolute OS.
(Run registry cleaner like ccleaner)
7. Inefficient Hardware.
(Any of the Hardware get problem might cause slowing down speed)
Follow these instructions to make faster your PC:
1. Go to start menu then write system restart and created restore point. If you install any program that may be the causes to slow your pc then it will helps you to make your pc faster.
2. Use more ram.
3. There may have some software that can also slow your pc.
4. Don't run too many application at once.
5. Defrag hard drive if you don't use windows 7.
6. Remove unnecessary files from temp, %temp%, recent, prefetch. For doing these go to run command and write one by one and delete files.
7. If you have low hard drive space then increase the amount your hard drive.
8. Remember one thing that there have some software, if you install those your pc might become slow.
9. If it doesn't work use boot time scan to detect the virus.
10. After doing these if your computer remain slow then create new partition.
11.If the machine are old that might me great reason for getting slow your pc.
1. Don't run too many application at once.
You can use pc faster tools for speed up your pc. It's remove unnecessary temp or dump files from your pc. More over you can install temp file cleaner.
Other hand you can fast your pc by using your system tools.
1. Click to START button.
2. Then click to All programs.
3. Go to Accessories and then System tools.
4. Click to Disk clean up option and select your drive to Scan.
After a few minute it will show the dump file. Click to delete.
Feel the different!
Try this first before doing the other steps that I make.
You need to diagnose first the reason why your PC going slow. You can start by installing a fresh copy of Operating system like windows xp windows 7 Etc. It is the best 1St Step to diagnose your PC it will remove viruses and other unwanted programs that runs to your PC that makes it slow. After done installing a fresh copy of the OS – Operating system and your PC is still slow then that’s the time to do the second step of diagnosing the hardware parts of your PC.
3. Scan for malware. Malware (virus, trojans, etc.) is a very common cause for slowing down a computer. Use an antimalware tool to scan for and remove malware from the computer.
4. Replace the computer. If none of the above-mentioned ways seem to speed up the computer, maybe it’s time for a new one. Many older computers do not fully meet the requirements for the new operating systems and software so they get slower.
