My computer is going down slow
My computer is going down slow day by day. I don’t know why. This is disgusting me very much.
If I do copy and paste it gets slower and slower .
How can I solve this problem ?
Hi! Mamun 01717,
There are many solutions to do. First of all you should empty your recycle bin. Another solution to do, if it does not work:
Solution number 1:
Download a program CCleaner, it can eliminate registry bloat and clear your cache and cookies so it would make a faster your work and also copy paste etc.
If you have Windows XP" Go to Start, click on Run and type cmd and press enter.
If you have Vista or Windows 7, go to Start and also search for cmd, right click on the program which will come in a window and select Run administrator. New windows will come where you type ipconfig /flushdns. It will clear your DNS cache and you will connect to websites faster.
Solution number 2:
Try to use this speed up tool. If it is now working well and if it is slow, there are a lot of other reasons as to why it is not working. Let me know and I will try to put another one.
Thank you and I wish you speedy computer.
