My Computer Is Showing A 0x800704cf Error While Sign-in To Microsoft Application. Guide Me To Fix The Issue.
Error code 0x800704cf is one of the most irritating issues the windows users face while configuring the internet or accessing Microsoft apps. The reason may be due to incorrect settings of TCP/IP, malfunctioning network devices, and using a local account to sign in.
The steps to fix error code 0x800704cf on windows 10
Method 1: Change adapter settings
Step 1: Right-click on the windows icon and select Settings from the popup menu.
Step 2: After setting the app appears, hit the network and internet option.
Step 3: Now switch to the corresponding right-hand side and click the change adapter option
Step 4: You will see every possible network connection here. Right-click on current Wi-Fi or ethernet and choose Properties from the context menu.
Step 5: Now uncheck Client for Microsoft network and tap on Ok to confirm the changes.
Step 6: After you have finished the above task, restart your pc and check if the problem is fixed or not while being of Wi-Fi connectivity.
