Harry Smith
Posted on - 07/16/2011
Good day experts!
I came across an error in my computers system. Here is the error that I am receiving from my computer:
"Error Loading C:WINDOWSSystem32ehkspkev.dll"
I can't seem to find any ways of fixing the problem I tried searching in Google and other search engines to find a way to fix it. But to my dismay I haven't found any that can fix the problem.
Error on loading drive C: ehkspkev.dll
dear submit error snap shot appears on your screen, so we will be able to help you further.
thanks
piyush
Hi Harry,
If you want to fix this problem then you can use any registry cleaner software and I recommend you CCleaner.
When you install the registry cleaner software on your system and run it, it will automatically detect the errors and will delete the registry of the unwanted or corrupted files.
If the registry cleaner software find that the registry is broken, the registry cleaner will replace or fix the file and your computer will become error free.
You can use the link to purchase CCleaner:
Using Registry cleaner software is better than the best way to make your system free from these kind of errors.
mjay3k
5 points
Did you just uninstall a certain program? Well ehkspkev.dll does not belongs to the trusted windows dll, probrably that dll was used by a own develop software or from adware and spyware. Download first a antimalware program recommended MALWAREBYTES and registry cleaner recommended CCLEANER. Those were shareware which you can download direct from their website for free. Install MALWAREBYTES and perform a quick scan. Restart PC when ask. Now install ccleaner and perform a disk cleanup and registry cleanup to fix registry related issues. Now type MSCONFIG at RUN window select startup and disable any entry that is related to ehkspkev.dll.
