I have a Dell computer that was working fine, however upon installing a certain software the computer request a restart and now will not boot, how can I restore this? I cannot get the computer to remove the software and I have no idea how to go about this. Is there a way that I can get the computer to restore without booting?
My computer keeps restarting and beeping twice continuosly
Hello
The windows system restore wizard is use full when you need to keep changes or setting get to your computer , Some time it can be problem matic. Whenever system cannot getting boot easily that time you need to get into safe mode. Some time it can be corrupted when the safe mode does not come up.
This is explain that how can performs low-level system restore without the wizard, Without internet and not need to boot the system.
First you have to get the file system. The simplest way to solve you need to use a DVD or CD bootable.
That might be PE type of windows likes bartpe.reatogo or it can be Linux .
If those are not have with you. You can be slave the hard disk to a running system. This way is simple to gain access the file system.
If your internal folder is set to hide the hidden file or hide the OS files which are protected. You should to turn off that kind of features.
Go to your file system and create the folder names as back up and copying all folder and files in created folder. You need to keep if in safe .
After that you to change your views options that can shows file and folder details.
There are many temporary files which are
Registry_user_.default
Registry_machine_security
Registry_machine_software
Registry_machine_system
Registry_machine_Sam
All the temper files you to rename
Software
System
Default
Security
Sam
After that you should copy all five files to "C:WindowsSystem32Config" to replace the files from the existing folder.
Now you need to shutdown the OS when you were using the re install the disk from your original computer system and no need to use the DVD/CD of OS bootable.
Now you should start the computer to get the back up. It can be booting to recover the system files from the stored system files.
