My Computer is restarting two or more times when booting up
When I want to start my computer, it needs to restart two or more times. How can I solve the problem?
This problem may be occurred by many different causes. At first you need to see that your power supply is work correctly. This type of problem is mainly occurred by the problem of power supply. Secondly your hard disk drive maybe is bad. If it does not work properly then this problem is create. Besides this you must see that the other hardware of your computer can perform correctly. If any other hardware is seems to be a problem you must repair or replace it. You must see all the jack and connection of your computer. I think this will be solving your problem. Thank you.
Hello Nicatail,
When you are starting the computer, are you connected to the internet? Because the reason why the computer needs to restart those numbers of times is because it has downloaded updates from the internet which requires that it starts for the updates to take effect and be functional.
It may needed to start the second and the third time because when it restarted the fist time for the settings to take effect, some other updates were downloaded which also required that the computer be restarted for it to take effect.
Another reason to that may be a problem with the operating system. Maybe some changes that you made to the computer did not agree with the operating system, you might need to run system restore to undo the changes.
__
Regards
Mahesh Babu
