digoo
10 points
Posted on - 08/09/2012
Dear,
I was working on my pc, suddenly it started shut down automatically. After few minutes I started againÂ
Then again after few minutes it shut down automatically. Please tell me how to manage with this problem?
My Computer shut down automatically
There are lots of reasons for it. If your PC infected with virus it will behave like that. Run antivirus to remove viruses. If your PC is overloaded it behave like that’s. Remove temp files, delete unwanted files, and remove unwanted software. Run Hard disk defragment. Increase RAM and processor capacity. Use light versions of windows like XP.
