Mark E Ward
30 points
Posted on - 11/08/2013
Hello experts,
I am getting this very annoying issue on my computer. It automatically sleep even if I am using it. When it's on again, it will just sleep again. This started when I opened Google Chrome to check on my Facebook while playing some videos in YouTube. This computer was new and yet this issue happened for two times now. I am running Windows 8 on my ASUS G10AC-ID003S. I don’t know how to resolve this. Please help me.
My computer sleep automatically even if Im still using it
The problem can be solved by making some changes in computer settings.
Change the settings by following the simple Instructions.
1) On the desktop do Right click and select “Properties” option.
2) A new Dialog box will appear, Click the "Screen Saver" option and then click the "Power" button tab.
3) Change "System Standby" to "Never" for either "Plugged in" or "Running on batteries" or both according to your requirement.
4) After doing above steps Click on Apply, “OK" and "OK" once again to close the Display dialog box.
