johnmark_01
10 points
Posted on - 08/24/2011
I am using XP SP2 and my computer screen blacks out ; my CPU turns off by itself after using it for like 3 minutes.
It is very frustrating when I do my work and I don't know what to do with it! The CD slot opens automatically by itself, when I try to turn it on after it blacks out. Also, I can’t turn it on, I must wait for about 5 minutes to do so.
Is it possible to stay on my Windows without formatting my PC.
Please help me!
Haque30
My Computer Turn off automatically itself.
You need not to be worried as following the instructions below will give a fine solution indeed-
• Click on the Start menu and go to the control panel.
• Click on the Performance and Maintenance -> schedule task.
• Double click on the Add scheduled Task.
• Click on the next option.
• Under given the option of “click the program you want Windows to run”, click on the Browse option.
• In the Select program of the 'Schedule' dialog box, locate the ""%Systemroot%/System32"" folder. Locate it and click on the Shutdown.exe file, and then click on the open option.
• Under the given option ""Perform this task"", you need to select a name for the task and specify how frequently you want to run this task -> now click on the next option.
• Under the option of 'select the time and day you want this task to start', type here a start time and date for the required task -> then click on the next option.
• Type user name and password to run current task and then click on the next option.
• Click on 'task' tab.
• In the Run box, type and add additionally required parameters that you need while using the shutdown.exe file. In the run
Line add switches after the exe-s and -r to reboot.
When the machine is reboot, there will be a message popped up, to warn anyone. At this time they will have 30 seconds to save their stuff.
kerubo
When such an error occurs. It mainly depends on the computer registry. The problem occurs mostly when the computer is affected highly by a virus. Therefore, an Antivirus must be installed to protect your computer and avoid restarting by itself.
Mostly make use of the Antivirus by updating it to protect the latest viruses that can be transported to your computer system. Without an Antivirus, the computer overheats and it restarts every after switching it on.
