ney steele
20 points
Posted on - 06/22/2012
Hi, I am having a problem in the installation of my D-LinkWBR 2310. It is showing error 112.
I have switched the modem for 10 minutes, but the problem didn’t solve at all.
If you have any information for solving this issue, then please let me know.
Thank you.
My D-Link WBR 2310 has an error
Ney Steele
Hi. In order to check this problem, you first have to check the physical connection between your router and the computer. Before proceeding you should have the user manual with you, if not the same can be downloaded here:
The connections should be: that the wire from the modem should be connected to the routers internet port. Than connection between your computer and the port1 of router should be present
After performing the above, Re Boot the router / modem and your computer.
Now, go to Star- run- and type “cmd” (without quotations)
On the Popup black screen type: “ipconfig /a” (again without quotation). The ip address of your computer will be displayed as well as the gateway, For the router it should be something like: 192.168.1.1.
If you still can’t see them, then the only reason could be that the router is defective.
PT
