raphael65
Posted on - 01/06/2012
I would like to enlist your help regarding saving my PST files in one location and transferring them to my new Mac. My PST files are currently saved in other locations. Also, I would like to transfer my data and files from my current PC to my new Mac. What is the cheapest way to do this?
Thank you so much.
My data and files from my current pc to my new Mac
You can easily transfer your PST files and data to your new Mac. There are several ways to do this, like; transfer the data by different software, by using USB, by portable hard drive etc.
You can also transfer the data by using an Ethernet cable. There is a software migration assistant, you can easily transfer your data or any file with this software.Â
But remember one that you should have software installed in your Mac, which the files requires. Then you just transfer from your old PC to new Mac by using that following software or through any other way which i have told you and use those in your new Mac.![Migration Assistant](https://www.techyv.com/sites/default/filesx/users/Images/Migration-Assistant-to-transfer-user-accounts-application-computer-settings-and-files.jpeg)
