My Dell laptop Stuck when internet is running?
Asked By 110 points N/A Posted on -
Can any one help me?
There is a problem with my laptop, no hardware problem but it's still stuck. I am in a big problem.
Can any one tell me if you are familiar with the same problem?
Best Answer by Najam
Answered By 220 points N/A #87444
Good day for you John!
Its the latest thread that runs on PCs. So make a backup on all hard drives. That's why the first thing that you have to do is reinstall your Windows. If you have registered Windows then uninstall all applications and do a recovery. Then install any best Antivirus. I hope you will fix it
Mike
Answered By 110 points N/A #87446
I have installed Windows 7 many times but problem still exists.
Answered By 0 points N/A #87447
Hi! Guyz,
These are latest threats and create backup in all drives.
First you will have to format all drives. Then reinstall/ recover Windows. If you are in local group of computers don't share any thing with the local group for some time of period. If the problem persists still, then comment here.
Najam.
Answered By 110 points N/A #87448
I have installed Windows and formatted all drives and then connected with my local group computers. I also changed the RAM DDR3 but the problem is not eradicated.
John
Answered By 220 points N/A #87450
Before you connect to the local group install AVG internet security 2011 and then enable this firewall and select option "Small home or office network". It will protect your system to penetrate any virus from other local group computers.
Answered By 110 points N/A #87451
Thanks for supporting guyz! AVG is the best solution.
Thanks again.
