My desktop automatically installed a NetGear driver download
I have a NetGear WNA3100 Wireless USB Adapter which I use on my Windows XP 64 bit desktop.  My desktop automatically installed a NetGear driver download and I'm now having an error of "Driver not supported".  Please help.  Thanks.
Answered By 40 points N/A #142881
Hi dear Elyssaguadalupe,
Most probable cause behind the problem is – The software which you installed is not right one. You have to check the software compatibility before download. If it says again error, Then you have to download the software manually.
Its not a hard task. Just go to the following site and download any types of driver. Here you find all types of drivers.
The instructions of installing drivers are attached in the link.
So no need to worry about.
