My Desktop Showing Acewstr.dll Error While Opening An Application
When the application in the system requires the acewstr.dll file. Windows look for the file in the systems folder, and if it is missing from the computer, then an acewstr.dll error occurs in the system. The error message appears on the system ‘This application has failed to start because acewstr.dll was not found. Re-installing the application may fix this problem’ or ‘acewstr.dll not found.’
The methods to fix the acewstr.dll error are as follows:
Method 1:
Re-install the application that requires acewstr.dll.
Method 2:
Install all the Windows and driver updates.
Method 3:
Update the application to the latest version
Method 4:
Download and install the dll file
Step 1: Visit the mentioned website.
Step 2: Search for the acewstr.dll file, and the file will appear of the size 871.1 KB.
Step 3: Download the file and place it on the system folders of the computer.
