My desktop shown duplicate icon ?
There maybe something wrong with the registry settings. Try to do these following steps:
Open the registry for Windows XP using these steps:
Go to Start and Select Run
Type regedit in the window and click OK
When the registry window is now open, go to the following folders: HKEY_CURRENT_USER Software Microsoft Windows CurrentVersion Explorer User Shell Folders
Then try to change the entries by Double-clicking Desktop and set it to %USERPROFILE%Desktop
Then go to the next folder: HKEY_LOCAL_MACHINE SOFTWARE Microsoft Windows CurrentVersion Explorer User Shell Folders
Change the entries again by setting Common Desktop to %PUBLIC%Desktop
Well, there is something wrong with the settings of your computer. Just explore its settings and try to troubleshoot the problem. If you cant solve it you need to hire and IT expert for that. Maybe you have changed its settings. Set the settings as default.
Thank you.
