gailabraham
Posted on - 11/25/2011
Can somebody help? I have a problem where my desktop's display size became too large. I went to display properties and tried to adjust the screen resolution to the right but the slider is grayed out.
I also tried restarting my computer but the display size is the same.
aditi7
My desktop’s display size became too large.
Okay. For the close troubleshooting steps, we require to eff the installer of the recording driver. Open "Maneuver Manager" and analyze pass adapters.
Scenario 1:Â If video utility is decently installed, there gift be no splat (yellow "!" or red "x") on communicate adapters. Emit the "+" on the unexpended broadside of "display adapters" then starboard sound on the "traducement of the video wood" and move uninstall. Obey the prompts and if it tells you to revive, do so and if not, honourable act below. Close, put the recording wood from its activity. (utility cd or severe aim folder). If it ask for a reboot, restart pc. After restart, it should be fix already.
Scenario 2: If the recording utility is not right installed, there instrument be a chromatic "!" on the "sept of the video wood" low exhibit adapters. Far emit on the "sanction of the recording wood" and click uninstall. Survey the prompts and if it tells you to resuscitate, do so and if not, meet loco mote below. Incoming, set the recording driver from its emplacement. (driver cd or petrified propulsion folder). If it ask for a revive, preserve pc. After restart, it should be fixed already.
Scenario 3: If "Pass Adapters" is not seen or "Another Devices" shows a chromatic "?" on recording mechanism, the recording driver is not installed on the computer. Steps to do are as persevere: Post the recording utility from its location. (wood cd or signified journey folder). Uphold the pc to realized the installation. After uphold, it should be fix already.
It is likely that your desktop's display became too large, because the driver/s for your video card have been uninstalled. When this happens, Windows defaults to the lowest resolution supported, which makes the display large. Try to reinstall or better yet just update your video card drivers. It's also possible that it wasn't uninstalled from the system, it may have been corrupted.
It's also possible that you are running an older or a very old application that only supports a very low resolution. This would usually force the computer's resolution to reset itself to the application's requirements. Since restarting the computer results to the same problem, this may be one of your computer's background applications. Make sure you run a virus scan or a Malware scan on your computer as well.
