Jody Akerly
80 points
Posted on - 09/26/2012
My DosFlash64 V1.8 has encountered a problem. The screenshot of the error message is given below.
If you have any idea in respect of the issue please help me to solve it.
DosFlash64 V1.8 20090808
No known flash chip on the port!
Hello Jody,
Make sure that you are using DosFlash in the right flashing mode. DosFlash has got support for two flashing modes: Auto and Manual. In the event that you type DOSFLASH at a DOS prompt it, and then it will start in Auto mode. All of the drives as well as the corresponding flash chips will be detected automatically.
If that does not work you will need to use manual mode, where you can enter all the parameters used for flashing by hand.
Nicke
