Rob Billman
210 points
Posted on - 06/30/2011
Hi Guys,
I downloaded a video, but it is an .flv format. I tried so hard to look for a .mp4 format, but I cannot find one.
My option is to convert it, because I cannot view it. Or I can also download a codec.
Any ideas on what is easier and practical to do? Kindly help me.
My downloaded video flv format won’t play
Dear there are many solutions for viewing such file, I am telling you some:
If you want to see the FLV files in your PC you should install VLC or 123 K-LITE player it will support all FLV players.
I f you want to convert the FLV to MP4 or any other file format that can be workable on you mobile device so an excellent is there for you with the name any video convertor. It is free software and having excellent things, you can convert any file format into any compatible file format. It has specific options for mobile devices and specific options for personal computer so you have many things in this software. I strongly suggest you to install that software into your pc it will help you a lot in converting filesÂ
For your ease i am also providing you the link of the software
http://www.any-video-converter.com/products/for_video_free/
Cheers
Best of luck
craig_IT
Hey Rob, you have opened a file format which is not yet supported by your system since no application is associated with it. I recommend you to install VLC player or GOM player which can install needed codec for you to play the file. Both of those software are free to download on their site.
