My driver updater pro 4 is not working properly
A driver updater software is really efficient in our job. But we had a problem in dealing with its use. We used different computers and they’re specs and software are the same versions. Yet the driver updater pro 4 was not accurate after scanning the driver’s status. How can I fix the software? How can I try to reinstall it ?
