My Droid x2 Camcorder problem
The camcorder on my Droid X2 is sometimes freezing up and giving pauses almost every time I recorded a video. I even set the resolution to the highest so that I can play that on my TV but it didn't work. Can anyone help me?
Answered By 0 points N/A #151491
These days, this problem is very common with Droid x2. But here is the solution. When Droid x2 freezes up or skips while recording, it doesn’t mean that the problem is in the camera or the resolution. The only problem is in your SD card. I will give you two solutions.
If you will buy a HD card for your Droid x2, this problem will not follow you again.
But here is the 2nd solution with any SD card. Just remove your SD card. Back up the important data. Plug it into your PC and format it. Then again insert it into Droid x2, use the camera and that’s it. Fixed!
