My Fedora 16 has encountered a problem. While opening GUI User and Group I received an unknown error message. I have no idea for the unknown error message. Have you any idea for the error message. Please help me to get a remedy of this issue.
Thanks in advance.
Well Mr. Janetdschall,
Fedora 16 is a user friendly Linux OS last I have used. You did not described about your UNKNOWN error message so it difficult to answer but I like to suggest you to visit given sites. You must describe your error message in detail there, so that the bloggers may help you faster.
Most of your problems are related to user mistakes. Did you tweak something try to set it on default values? If you didn't touch anything then wait for a new update to be released, and probably your problem will be solved. Also you should run the System test software, this will find any errors in your system. Regards.
