anna scott
20 points
Posted on - 08/19/2019
My files are not Syncing with my one drive. Help me fix the syncing issue.
My Files Are Not Syncing With My One Drive
One Drive is Microsoft’s cloud storage; it’s free and has Office integration, so it is highly popular and easy choice.
However, it does have troubles syncing your files. If you notice that some files aren’t syncing, here are solutions to help fix the problem.
- Try to Access One Drive Online
- Restart One Drive
- Ensure You Have Enough Storage Space
- One Drive capacity
- Check for Incompatible Files
- Update Windows and One Drive
- Check for updates in Windows 10
- Relink One Drive
- Unlink One Drive account from PC
- Temporarily Turn Off Protection
- Move Stuck Files Out of One Drive
- Disable Office Upload
- Office sync setting in One Drive
- Fully Reset One Drive
