raazbd
Posted on - 11/18/2012
1)Â Â What is called 'captifyContent' in Joomla Images Grid?
2)Â Â Â Can the plug in turn any folder of images located inside the Joomla?
3)   Who is the developer of ‘Image Grid FX’?
4)Â Â Â Does the Image Grid supports an unlimited number of rows and columns?
My First Four Questions Regarding Joomla Images Grid!
Hello Raazbd,
Here are the answer, hope this helps.
Captify content in Joomla Images Grid is a new way to display image attached in your joomla sites in a grid based layout. This module will resize the image that you have assigned to a simple grid.
No, the images need to be selected first.
The developer of Image Grid FX is FlashXML.Net
Yes, it does supports an unlimited number of rows and columns.
Stonjhon Llison
Hi there Raazbd,
Image grid FX is a lovely non-commercial Joomla 2.5 add-on created to help you place your images into a stylish grid presented on your website using simple flash application. Developer of the Image Grid FX is FlashXML.
Once you install the add-on, you will need to select the images and adjust the options to fit your webpage. The number of rows and columns is unlimited, just as the number of images you can place inside the grid, but keep in mind that maximum size of the grid is 1680×1050 pixels and that this is a flash application so too many images could slow down your website.
While you're there, you may want to check the complete Image Flash Slideshow section just to check the alternatives.
Best regards,
Drake VivianÂ
