My galaxy won’t turn on please help me!!!
I downloaded some game to my phone then I played it and after 2 minute it stuck so I removed the battery and I tried to turn it on but it's won't start please help!! My phone is galaxy Mini GT-S5570I.
Hello Roei24w,
I think in the process of hastily removing the battery you may have bricked your phone. You can try the power up combo which is volume up + power button. Long press them for 30 seconds if nothing happens then you should take the phone to a certified technician for repairs.
Hi. Roei24w,
It happens sometime well that’s not such a big problem. Actually, what you phone is demanding is reinstall phone software i.e. Updating which you can do my visiting to the link I am providing.
Kindly visit galaxy update
I have tried it myself and I will recommend it to you too. You need to update your phone software.
I hope that this will fix your problem.
Thanks & Regards
Gillam Janetj
