My gamebox.exe just got broken
My gamebox.exe just got broken. What I did to solve it is copy the same .exe file from another computer and replaced the broken file, but then I get this error message.
How do I fix this?
GAMEBO~1.EXE An error occurred in the application
GAMEBO~1.EXE
Best Answer by Johnson Melanie
Answered By 0 points N/A #190378
Hello Joseph,
To fix that issue, you will need to use the following steps:
  • First of all you will need to download and then install unLZ.GBA.exe Windows Errors Fix Tool for FREE.
  • After that you will run a Performance Scan Your Computer.
  • And then click the 'Repair Error' Button to Repair your system.
Nicke
Answered By 0 points N/A #190379
Hi Joseph,
You cannot just copy the exe file, you also need to copy the other files.For example, if there are some DLL files or DAT files, you must copy those too.
What's more, if gamebox's data file is changed, you also need to copy the user's file, which records your played history.
Best wishes.
