My Google calendar is functioning properly when it is on the browser. However, I am getting an error when I try to sync my list of calendars from Google. Here is the error that I am getting: “Cannot connect to Google Calendar service”. Please help me in fixing this issue.
Your operating system should be WinXP or Mac OS 10.6.8. Other OS may cause these types of problems sometime. Delete the event(s) in the browser access to your calendar. Also check your system configuration whether it supports excess list of calendar because the number often varies. Try set up your accounts once again. Finally delete the event on your Google calendar and then stop popping back. Hope everything regarding sync will just be fine. Always try to remove unnecessary lists away from your Google calendar and only this way, you should enjoy sync list safe and nice there. Thanks for your question.
