My Google Chrome suddenly closes
Hi experts.
I really need your help on this problem.
Everytime I opened up my google chrome and loads google.com, it suddenly closes.
Could somebody tell me what causes this?
What should I do? Thanks.
Hi experts.
Try to go to C:Documents and SettingsobryanLocal SettingsApplication DataGoogleChromeUser Data and delete the Local Temp File of your username (the account you are using). Open the compresses chrome.7z zip file then open chrome.exe . I don't really know how it happens, it happens for a lot of reasons. Maybe it's because of your cookies, maybe you just have to clean your cache, have to reboot it or maybe you tried to tweak something that affected the browser or a virus.Hope it works. If it doesn't maybe you just have to clean up the cookies or use CCleaner and other anti virus scanners to check if it is a virus related issue, which I hope is not. Goodluck!
If your Google Chrome web browser is working properly that shouldn’t happen. Try uninstalling Google Chrome then clean your system from unwanted files using CCleaner and then install the latest version of the browser. Since Google Chrome is not working, start Windows Internet Explorer then go to CCleaner Free Download. Download and install CCleaner on your computer.
Once installed, click Start, Control Panel, and then “Add or Remove Programs”. Scroll down and select Google Chrome then click Uninstall or Remove. Once uninstall is complete, start CCleaner then clean your system. Afterwards, restart your computer. Next, start Windows Internet Explorer then go to Install Chrome Offline on Windows to download the standalone installer for Google Chrome.
Once downloaded, run the installer to install the latest Google Chrome on your machine. See if this fixes the problem. By the way, if you want to register your copy of CCleaner, go to CCleaner License Codes and download the file. Use the supplied password to unpack. Use 7-Zip to unpack the file. Download 7-Zip from 7-Zip File Compressor.
Once unpacked, open the file using Notepad and copy the license code to register CCleaner. In case the problem continues, use a different browser instead. Try the Opera Browser for Windows or maybe the latest version of Mozilla Firefox.
