D Wright
10 points
Posted on - 08/05/2016
The Google Chrome application on my Windows OS crashes every time I try to process it. The error says err_connection_refused and the Webpage doesn’t load. Any solutions to the problem ‘Google Chrome won’t open’ will be very helpful!
My Google Chrome Won’t Open At All!
You can repair the Chrome if it doesn’t load by the following. Firstly, try the simplest solutions:
• Close all other tabs
• Restart Google Chrome
• Restart your computer/laptop
If the above method/solutions do not work, try these:
• Check if Chrome is already open in background processes from the task manager.
• Adjust your anti-virus settings for malware or viruses.
• Uninstall, and then Reinstall Google Chrome.
