My Great DVD failed to burn DVD
I am trying to burn a DVD with separate videos but I get the following error message when I try to do this act. The error shows “There was an error during movie encoding”. What does it mean? Any help would be appreciated. Thanks.
My Great DVD
Encoding video
There was an error during movie encoding.
Answered By 0 points N/A #182374
The error messages might be coming about because you don’t have codecs installed on your computer. A Codec is a computer program that both shrinks large movie files and makes them playable in your computer. You need codecs because music and video files are large therefore became difficult to transmit. To speed down load they encode a signal for transmission and decode for viewing and editing. You will only need the ones that play your files.10-12 codecs are needed to play your files if you are a regular downloader. Examples of codecs are MP3, Real video, Real Audio. I would advise you download the K-Lite codec pack. It is a user-friendly solution for playing all your audio and movie files.
