My heat map settings do not show in windows HPC
60 points
Posted on - 02/06/2015
I have set up a heat map in windows high performance computing to show 3 statistics in every given box. Whenever the servers are using a lot of the memory, I open HPC and the heat map is turned back to the default state. Why is that? In addition, when I close it, it takes a lot of time to open again. Why? Please help.
