Why does my Hewlett Packard Omen laptop battery drain quickly while gaming? I recently bought a Hewlett Packard Omen laptop and the battery barely lasted for one hour while gaming, although under normal use the battery does last for four hours. My friend HP omen laptop battery lasted for almost three hours during gaming, but under normal use, the battery last same hours with mine.
My HP Omen Laptop battery drain faster than usual
I think that you are using heavy games on your laptop. So they are draining your battery faster.
Here are the ways by which you can increase your battery life.
1) Close all the application which are not in use by using keys CTRL+ALT+Delete and then go to task manager and end all the applications that are not in use.
2) Keep your brightest low if you are using it in dark place.
3) Use your laptop while charging as much as because it will increase your battery life.
4) Does not go down your battery too much lower because it will affect your battery life.
