My Icons are disappeared. Why? How I can get back?
I am using windows XP.
I had all the icons before sometime. Now I have not any icon on desktop.
I can see just taskbar.
Hello Dear,
Thanks for sharing your problem.
Dear in windows XP, there is an option that can appear and disappear the desktop icons.
If you want to get them back, do as I say.
Right click on desktop, choose arrange icons.
In arrange icon’s list, click on “Show desktop icons” now see all the icons will be back on your desktop.
I hope you got the answer.
Thanks
This is because the Show Desktop Icons feature is turned off. To fix this, right-click on your Desktop and then select "Arrange Icons By" and then click "Show Desktop Icons". And also, you can customize your Desktop by adding the desktop icons. Simply right-click on your Desktop and then click "Properties". Under the Desktop tab click "Customize Desktop". And under the Desktop Icons, tick the check boxes of the icons that you wish to see and then click "OK" twice.
