My important wedding photos got corrupted
Hello techyv.com!
I have here a Digicam with memory stick, and this is the camera that I've used during my wedding. It was well fine and usable until my nephew plays with a magnet and accidentally threw the magnet beside the camera and left there for few hours before I noticed it. Now as expected, all the data in the memory stick got corrupted. Anyways, I've read about photo rescue 5. Can it recover my pictures even it was corrupted by a magnet? It's kind of expensive though.
Best Answer by oliverpowell
Answered By 40 points N/A #129801
Photo rescue 5 is expensive, However there are quite a few other software available that can recover your precious wedding photograph, I have arranged a couple of links, which will help you to recovery the data, Plus both the software are for free download
http://www.softpedia.com This link contain photo rescue wizard,
It Works with all the types of media used in digital camera, SD Cards, Cards, Memory Sticks.
http://ccm.net/download/download-2862-digital-photo-rescue-software
This software works perfectly fine with jpg, JPG, TIF, JPEG, GIF allows to recover the removed photos
Thanks
Answered By 50 points N/A #129802
Dear Maxine,
Thanks for stopping here. Perhaps, you're at the right place and will get the best possible solution here.
I haven't tried the software you've mentioned above but would glad to assist you in recovering photos from damaged memory card using different software entitled 'Stellar Phoenix Photo Recovery Software' from Stellar Data Recovery.
Download it from here: https://www.stellarinfo.com/digital-media-recovery.php
The software is pretty fast and able to recover almost any kind of photo file type from major camera brands like yours. The software has the option to customize your search results to minimize time taken for scanning the whole media. Give it a go and see what happens.
Don't forget to post back with your status or if you need additional help.
Hope it helps!!
