My inline graphic is too big
My inline graphic is too big, don't browser automatically resize graphic according to the width of the of the window the way they wrap text?
If you insert an image or any graphics in your web page and you did not add the elements width and height, the web browser will normally display the image as is with its actual size or dimension. If the graphics is too large for the line, not adding the width and height elements will make it look awkward since it is very large to be displayed for that line only.
In cases where images are in big sizes, adding the width and height elements will help you adjust how it is displayed in the page. It is very helpful especially for extremely large graphics that needs resizing but you don’t want to physically adjust the size of the image. To apply the 2 elements in your image, follow this format:
When applied, you can have something like:
By the way, width and height elements can be inserted interchangeably.
