Hi guys,
I want to know the solution to this problem so please help me. I bought Intel smartphone for the first time and it does not connect to internet why guys this a smartphone right? but wont connects at all I have made all the necessary settings too but its same problem. Will restore settings work for this?
My Intel A2 smartphone does not connect to internet? Why?
Hi Robby, You mentioned the chipset name Intel A2, but if you do have a smartphone, just try to go to your home screen, then tap Settings, from here go to Wireless & Networking and then go to WiFi Settings and enable your WiFi. From there you could automatically connect to your router for internet access. If you are going to use your phone as a hotspot disable your WiFi first the enable your Mobile data which can be found in the Settings then More Settings and Mobile Data.Â
