My internet connection is not working perfectly
Hi. I use WiMAX connection in my home. For the last 2 days, my download speed isn't getting any higher than 6kbps, where i had used 50 kbps constantly with this line. Then when i connect the router into another pc, it works perfectly. What is wrong with my pc? What do i need to do?
