anonymous
7060 points
Posted on - 08/02/2011
I have a problem, when i open most of the sites this exception occurs; can anyone tell me about this.
Exception "An invalid or illegal string was specified"Â code: "12" nsresult: "0x8053000c (NS_ERROR_DOM_SYNTAX_ERR)"Â location: "chrome://plugin/content/jquery-1.4.2.min.js Line: 112"]
sibabu
5 points
My internet shows a Script error
This message you got from chrome is published that your web site connection server cannot go which you want to run.
Your file may be corrupted or victim. Go tools and set the connection or network connection.
Or you can make it re install properly. For using
James14
May be you are entering on an blocked web page.
If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
1.      On the Tools menu, click Internet Options.
2.      On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
2.      On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Hope it will solve your problem.
