My iPad 2 Becomes Sluggish
iPad was very fluid and responsive when I first bought it. However today, it felt as though there are some things that are dragging my iPad down. Games begin crashing, animations felt a bit slow than normal and sometimes it just don't work. What can I do to make iPad as fast as it was before? I'm using iPad 2.
Answered By 0 points N/A #108031
Hello
Don’t worry that is nothing. You just delete the app you think that are slowing your iPad2. You can do that by few very simply steps. First sync application that you have bought from iTunes. And after that make sure that you have disconnect iPad2 from your PC.  Next step will be deleting applications that make your iPad2 work slowly. Delete them all. After that just press Home. Next step will be Sync. You can do that by connecting your PC and iPad2. In the iTunes app make sure that all app you have deleted are selected. After that just press Sync. Sync is finished just turn of your iPad2. After few seconds you can power it on. And you can see your iPad2 is much faster.
Hope i helped to you.
