Hi guys,
My iPhone 3G has encountered a problem. It’s touch screen becomes insensitive very often. Lock it and unlock the phone may sometimes get a remedy. However, it happens at an irregular interval. I have installed different Cydia-packages on my jailbroken. Please help me to get a remedy of this issue.
Thanks in advance.
lee hung
75 points
It happens when Iphone is running on low memory. A good solution for it is to make sure you close the application after use. Double press the home button, it will show you the running applications, tap on any of the applications long enough that a red (-) sign appears on them and then close the application by tapping on that sign.
Another but more effective way would be re-installing the iOS on your Iphone. Hope this will work for you.
