Christofer
410 points
Posted on - 06/23/2011
I'm using iPhone 3GS for the last 7 months. Two days ago suddenly when I opened my calculator icon, it was not working. I tried several times, but it freezed; nothing was happening. I tried with restoring, but still it's not working.
I used it very carefully, so no accident had occurred with my iPhone. I don't know what happened.
Please someone help me.
Cheers,
Chris
My iPhone 3Gs touch screen is not working
If you tried using the calculator but the phone freezes unexpectedly, try to turn off your phone for about a minute or two and then turn it back on. Use the calculator again and see if it works. If this doesn’t work, try doing a hard reset. First, turn off your phone.
When the phone is completely off, connect the USB cable to the phone and then start iTunes on your computer. Press and hold the “Home” button on your phone then connect the cable to your computer. When iTunes detect your phone in recovery mode, just click “OK.” In iTunes, click “Restore” and then “Restore and Update.” Wait until iTunes is finished restoring your phone.
Performing a hard reset on an Apple iPhone will reset the phone in factory default. This should fix the problem. If this doesn’t work either, I guess it’s time to bring your phone to an Apple service center for proper servicing.
